Oldironsides
Mar 10, 2020Guide
RBR50 gets 900Mbps ethernet to PC, RBS50 gets 400Mbps ethernet to same PC
Hello Orbi Community, Thank you for taking the time to view my post. Just bought the Orbi AC3000 kit from costco to maximize my 1gig internet speed provided by Comcast. I must say my wifi sp...
Oldironsides
Mar 10, 2020Guide
Thanks you FURRYe38 for replying to me.
The router and the satellite are about 20 feet away from each other. I have no coaxial in living room. So main router in bedroom hardwired to modem. Next room over, I have the satellite behind my tv, hardwired to my PC.
I made the changes in which you suggested, rebooted the router and satellite and still am getting lower than desired speeds. Did get one test at 520Mbps, so we are getting better.
Any other suggestions?
Mar 10, 2020Guru - Experienced User
20 feet is too close between the RBS and RBR...
- OldironsidesMar 11, 2020Guide
Thank you. I will relocate the router to anoher room and place the satellite a little further away. I will report back tonight after work.
- OldironsidesMar 11, 2020GuideMoving the satellite and router further apart did not correct my wired speed from the satellite.
- Retired_MemberMar 12, 2020
Oldironsides wrote:
Moving the satellite and router further apart did not correct my wired speed from the satellite.what firmware are you using?
- OldironsidesMar 12, 2020Guide
both the orbi router and the orbi satellite are on firmware version 2.5.1.8
Oldironsides wrote:both the orbi router and the orbi satellite are on firmware version 2.5.1.8
There's your problem....
