Oldironsides
Mar 10, 2020Guide
RBR50 gets 900Mbps ethernet to PC, RBS50 gets 400Mbps ethernet to same PC
Hello Orbi Community, Thank you for taking the time to view my post. Just bought the Orbi AC3000 kit from costco to maximize my 1gig internet speed provided by Comcast. I must say my wifi sp...
SW_
Mar 12, 2020Prodigy
Oldironsides wrote:
Just bought the Orbi AC3000 kit from costco to maximize my 1gig internet speed provided by Comcast. I must say my wifi speeds are amazing (roughly 500 - 700Mbps)... I get about 400 Mbps from satellite and I get 900 Mbps from main unit (same PC, long ethernet cord).
Are these units capable of delivering close to gig speeds with a ethernet cable connected to satellite Orbi???
Unless it's wired backhaul setup, it's unlikely you'll get anything close to Gigabit via Ethernet connection from Satellite. Check Orbi/Satellite wireless backhaul linkrate , which should give an idea of what to expect. I also have Comcast Gigabit and my wireless backhaul is steady at 1300Mbps. My max download speed via Satellite is similar to yours on a good day ~500Mbps. On a bad day it's half, hovering around 250Mbps-300Mbps.
Orbi Internet Speed Tier:
Mar 12, 2020Guru - Experienced User
Just curious, you have not seen wireless backhaul connection rate between the RBS and RBR with 1733Mbps? I presume this would only be achived in near perfect conditions.
- SW_Mar 12, 2020Prodigy
No. I've not seen 1733Mbps in my current setup. Here is what Orbi backhaul shows right now for the 2 Satellites:
root@RBR50:/# wlanconfig ath2 list ADDR AID CHAN TXRATE RXRATE RSSI MINRSSI MAXRSSI IDLE TXSEQ RXSEQ CAPS ACAPS ERP STATE MAXRATE(DOT11) HTCAPS ASSOCTIME IEs MODE PSMODE 14:59:c0:3b:xx:xx 1 157 1300M 1300M 36 35 49 0 0 65535 EPs 0 b 0 AWPSM 00:09:19 RSN WME IEEE80211_MODE_11AC_VHT80 0 14:59:c0:3b:xx:xx 2 157 975M 975M 32 31 41 0 0 65535 EPs 0 b 0 AWPSM 00:00:37 RSN WME IEEE80211_MODE_11AC_VHT80 0
- FURRYe38Mar 12, 2020Guru - Experienced User
Whats the distance between the RBR and RBS?
Probably distance, environmet and building materials will be a factor in not seeing 1733Mpbs I presume.
SW_ wrote:No. I've not seen 1733Mbps in my current setup. Here is what Orbi backhaul shows right now for the 2 Satellites:
Distance is roughly around 50ft to 60ft to each Satellite respectively. I might get higher backhaul linkrate with line of sight, but it's not practical given the walls in betweeen nor it's likely going to make much of a difference for daily use. As long as I don't hear/get a complain about disconnect/slow WiFi speed, 250Mbps-500Mbps with full WiFi coverage/range is good enough.
