Oldironsides
Mar 10, 2020Guide
RBR50 gets 900Mbps ethernet to PC, RBS50 gets 400Mbps ethernet to same PC
Hello Orbi Community, Thank you for taking the time to view my post. Just bought the Orbi AC3000 kit from costco to maximize my 1gig internet speed provided by Comcast. I must say my wifi sp...
Mar 12, 2020Guru - Experienced User
Just curious, you have not seen wireless backhaul connection rate between the RBS and RBR with 1733Mbps? I presume this would only be achived in near perfect conditions.
SW_
Mar 12, 2020Prodigy
No. I've not seen 1733Mbps in my current setup. Here is what Orbi backhaul shows right now for the 2 Satellites:
root@RBR50:/# wlanconfig ath2 list ADDR AID CHAN TXRATE RXRATE RSSI MINRSSI MAXRSSI IDLE TXSEQ RXSEQ CAPS ACAPS ERP STATE MAXRATE(DOT11) HTCAPS ASSOCTIME IEs MODE PSMODE 14:59:c0:3b:xx:xx 1 157 1300M 1300M 36 35 49 0 0 65535 EPs 0 b 0 AWPSM 00:09:19 RSN WME IEEE80211_MODE_11AC_VHT80 0 14:59:c0:3b:xx:xx 2 157 975M 975M 32 31 41 0 0 65535 EPs 0 b 0 AWPSM 00:00:37 RSN WME IEEE80211_MODE_11AC_VHT80 0
