Oldironsides
Mar 10, 2020Guide
RBR50 gets 900Mbps ethernet to PC, RBS50 gets 400Mbps ethernet to same PC
Hello Orbi Community, Thank you for taking the time to view my post. Just bought the Orbi AC3000 kit from costco to maximize my 1gig internet speed provided by Comcast. I must say my wifi sp...
aakshey
Mar 21, 2020Star
In a 800 sq ft home, a single Netgear X4S will work better than RBK50. Just place centrally.
Oldironsides
Mar 21, 2020Guide
My issue is the apartment wiring. There is no coaxial in the living room so I can't install a router in center.
A little weird I know, both bedrooms have cable hookups but living room nothing. Just trying to find a solution with what I got. without rewiring or routing new lines.
Another curve ball is my PC does not have a wireless adapter, only an Ethernet network card.
I like the idea of the orbi satellite located behind PC and plugged in Ethernet.
- aaksheyMar 21, 2020Star
Run an external CAT6 wire along your wall. From the router to the satellite.
