joanba
Mar 30, 2021Tutor
RBR50 gets stuck every day
Hi,
I've installed an Orbi RBR50 router with two satellites RBS50 at home. Firmware is current, V2.7.2.104. It has been working normally few months since I installed the kit last summer, but since two weeks it hangs everyday. I work from home, and now the first task I should do is to reboot the router. Router is directly connected to my internet provider (PPoE) and when seems to be stuck I can ping ip addresses in internet, DNS resolution seems to work, but no way to have any connection from browsers or other applications like VPN clients. So no connectivity. I fix the issue with a daily reboot of the router but I think this is not normal. Router is not accessible with orbilogin.com URL but it's accessible with LAN ip address (static).
Logs seem to be not helpful. They show lots of DoS attacks, RST scans, but I think this is not the root cause. I would like to know how can I have some diagnostics about what's ocurring. In router status everything is always green.
I'm discarding any issue with satellites as I'm always testing directly connected to router.
Any idea ?
Joan Altadill
Have you seen this thread, and the solution proffered by CrimpOn? I haven't tested yet but at least it's a way forward: https://community.netgear.com/t5/Orbi/Really-strange-connectivity-problem/m-p/2078027#M118189
- estegGuide
Try desactivating TM (Traffic Management)
Regards
Quick update: fix (disabling traffic management) appears to be working. I'll post again if it fails.
Really appreciate the help on this - was driving me crazy!
- joanbaTutor
I disabled traffic meter yesterday and today I'm working normally without reboot. Troubleshoting section on user guide recommends it for this symptom. Also found the way for debugging with https://orbilogin.net/debug.htm page ( same admin credential ).
Joan
