Umang4
Jan 27, 2019Aspirant
RBR50 going offline
My RBR50 is connected to a satellite and Huawei 8040 Bridging modem. It is going offline once every a day or so. To restart it, we need to switch off the modem and restart it after a min or so. Any a...
ekhalil
Jan 27, 2019Master
This looks to me a double NAT issue.
One quick way to test if double NAT exists is a traceroute.
Please open a Command Prompt on any computer connected to Orbi and type:
> tracert 8.8.8.8
to see the traceroute to Google’s DNS server. If you see two private IP addresses listed in the first two hops then you have double NAT. If you see only one private address and the second hop shows a public address, then you’re all good. :)
Umang4
Feb 04, 2019Aspirant
Thanks. I do have double NAT but not sure how to resolve it? Any advise. Thanks.
