Umang4
Jan 27, 2019Aspirant
RBR50 going offline
My RBR50 is connected to a satellite and Huawei 8040 Bridging modem. It is going offline once every a day or so. To restart it, we need to switch off the modem and restart it after a min or so. Any a...
Umang4
Feb 04, 2019Aspirant
Many thanks for your advise. My ISP router is Huawei Echolife HG8040. My satellite connects well and it is about 30 ft away. I have changed the channel for 2.4 from auto to 11. The issue still persists. May be i need to call my ISP? Any other advise. Thanks in advance.
ekhalil
Feb 04, 2019Master
Do you have the manual for your router?
You have two options:
- Keep using the Huawie Echolife router as your main network router and set Orbi in AP mode.
- Use Orbi as the main router but then you need to access the Huawie router and set it to Bridged mode, Passthrough or DMZ forwarding depending on what is avaiable in the Huawie settings, I could not find a decent manual for it.
