db4eddie
Jan 29, 2020Aspirant
RBR50 guest network Google Hub Nest or Chromecast
RBR50 allows main network to connect with a new Google Nest Home and Google Chromecast but gives error message/ won’t finish connection when trying to connect using Orbi guest network. I have reset th...
Jan 29, 2020Guru - Experienced User
Why are you connecting IoTdevices to the Guest network? Most IoT should be connected to the main wifi network.
