db4eddie
Jan 29, 2020Aspirant
RBR50 guest network Google Hub Nest or Chromecast
RBR50 allows main network to connect with a new Google Nest Home and Google Chromecast but gives error message/ won’t finish connection when trying to connect using Orbi guest network. I have reset th...
Jan 29, 2020Guru - Experienced User
Why are you connecting IoTdevices to the Guest network? Most IoT should be connected to the main wifi network.
db4eddie
Jan 30, 2020Aspirant
e)
Firmware of Orbi is 2.3.5.30
Of iPhone is IOS 13.3
Modem is Ubee with model # DDW36C
I am trying to connect the Nest Hub via Orbi Guest because the Nest Hub is in our guest house on our property and I don’t want to give our guests access to the main Orbi network I use for business and personal WiFi
- michaelkenwardJan 30, 2020Guru - Experienced User
db4eddie wrote:
I am trying to connect the Nest Hub via Orbi Guest because the Nest Hub is in our guest house on our property and I don’t want to give our guests access to the main Orbi network I use for business and personal WiFiSetting up IoT device on the main network will not suddenly give guests access to the main network.
