wonderbliss
Apr 01, 2020Guide
RBR50 Guest Network Stopped Working
My guest network has stopped working, and I have no clue why. Help page says to upgrade to latest firmware version. I've done that, at least as far as Netgear will let me manually (to V2.3.5.30). Aft...
Apr 01, 2020Guru - Experienced User
Try disabling Guest network on the RBR. then reboot the RBR, then go back in and re-enable Guest network on the RBR.
Use a PC and web browser to do this with the RBR.
- wonderblissApr 01, 2020Guide
Thank you very much. I'll try that and report back if it worked or not.
