orbiinthehouse's avatar
Mar 20, 2022
RBR50 half wifi speed
Hello all, I have Gigabit Internet in the house. Then a RBR50 in AP mode connected to the modem downstairs. And RBS50 is upstairs wirelessly backhaul to RBR50. Both are on firmware: V2.7.3.22 When ...
  • plemans's avatar
    Mar 21, 2022
    The 400mbps is more realistic. I'm highly doubtful you're getting 800mbps over wireless. Not sure how you're testing it.
    The reason why is the RBR50's fronthaul (what devices connect to) is only 866mbps link speed. And link speed isn't throughput speed. Because of network overhead, actual throughput tends to be around 55-65 (some will hit 75%) of what link speed is.
    So even if you're connected at the 866mbps link, you're actual throughput is 400-550mbps.
    I'd take a look at a tested review from a site that does a great job of testing and actually goes over specifics of how they're testing.
    https://www.smallnetbuilder.com/wireless/wireless-reviews/33028-netgear-orbi-reviewed
