LEWB71
Oct 03, 2020Aspirant
RBR50 Hardwire satellite
I have an Orbi RBR50 router with an an Orbi52 Harman/Kardon speaker satellite. I ran a Cat5e Ethernet cable between the two to have the satellite hardwired to the RBR50 router. My ISP is Verizon Fios...
- Oct 04, 2020If the RBS40V shows connected you have completed the setup. Now you are ready to setup the Alexa mode.
I would ignore the status if the satellite shows good and is working, as should. The GUI and app can report wrong.
LEWB71
Oct 04, 2020Aspirant
I found that holding in the RBS40V power button and sync button simultaneously is the method to change the RBS40V mode from Extender to Satellite mode. So I did a factory reset of the RBS40V (hold in the reset button until it pulses Amber). After the RBS40V restarted it automatically defaults to Extender mode. I changed the mode back to Satellite. To where the light ring on top pulses white and then becomes solid white. But it only stays white for a second then becomes blue. I think this means it’s back in Extender mode. When I then do a sync it shows back up on the Orbi app as a 5G connection. I have to initially place the RBS40V close to the RBR50 so it will recognize it. I’ve actually gotten gotten it to work and stay as a wired connection. But then, when I unplug it and move it where I want it, it of course, reboots and goes right back into a 5G connection. I have done this so many times I’ve lost count.
During the reset process it says something to the effect “Orbi is ready to sync. Follow the instructions from the Orbi app”. I’m not sure this needs to be done. The Satellite already shows up on the network map before I do that. But when I have followed those instructions that’s when it reverts to the 5G connection.
Any further help in solving this issue is greatly appreciated.
Mstrbig
Oct 04, 2020Master
- LEWB71Oct 07, 2020Aspirant
Your instructions were absolutely dead on correct. I finally got everything to work. A big problem was my dyslexia in putting on the RG45 connectors. I had the wires correctly aligned but had the connector upside down when I cripped it to the cable. It's the small details that can screw you over. Thank you for all of your help, support and quick responses. I find the Community support is always invaluable.
