Wayland25
May 25, 2019Aspirant
RBR50 has not "security" tile in the app
I keep getting notifications to use the NETGEAR Armour features, and to locate the "Security" tile in the Orbi app. But, the app has several tiles ("network map," "device manager," "internet speed,"...
CrimpOn
May 25, 2019Guru - Experienced User
p.s. maybe you need to scroll down?
Wayland25
May 26, 2019Aspirant
Yes, I thought of that. I might be a novice at Netgear, but .................. :)
- CrimpOnMay 26, 2019Guru - Experienced User
Is your Orbi in "router" or "access point" (AP) mode?
In AP mode, things like Security do not seem to apply.
- Wayland25May 26, 2019Aspirant
A-HA! That's it. Thank you very much.
This has been driving me nuts. There is no discussion of that in any of the instructions.
Thanks for figuring it out!
