JTrtt
Oct 08, 2018Tutor
RBR50 heavy battery drain on iPhone SE
Purchased RBR50 on 08 October 2018. Firmware V2.2.1.210
One Orbi Satellite-1
Six connected devices: Two iPhones running OS/12, a Windows 10 Desktop, a printer, a Roku, a sterio receiver TX-8170
- Oct 13, 2018
Good to hear. Mark this thread as solved so others will know when needed.
Enjoy. :smileywink:
JTrtt wrote:
I promised to update after a few days of testing. After doing the following, the battery drain on my iPhone SE has improved so that it is only consuming 10%-20% per day which is very much better than I had before. I am encouraged. Thank you FURRYe38 and pdang for the help!
Here is what I did:
On the Orbi RBR50
- Enabled MU-MIMO
- Enabled Beamforming
- Enabled Fast Roaming
- Enabled Daisy Chain
On the iPhone SE
- Disabled Screen Time (a huge improvement; see https://www.idownloadblog.com/2018/10/08/ios-12-screen-time-iphone-battery-drain/)
- Turned off Background refresh on apps I don't need
- Started using Airplane Mode + WiFi while at home. An article suggested this would save both because both radios are not on and it is not constantly checking for cell coverage. I don't know if that is true but it seems to have helped.
JTrtt
Oct 10, 2018Tutor
Thank you for the advice so far. I have done the following:
- Enabled Beamforming and MIMO
- Disabled Screentime on my iPhones (by default, it was enabled on my phone and disabled on my wife's)
- Reduced power on the 2.4 GHz channel to 25% (only used by my printer)
I am also looking at using Airplane Mode (with wireless on).
I reckon I need to test this for a day or two to see if this resolved the issue.
I will update this note by end of the week.
Oct 10, 2018Guru - Experienced User
Sounds good.
