sparkman
Nov 07, 2020Aspirant
RBR50: Help with IPv4 PPPoE setup
Like a few people that have posted here, i'm looking to bypass my Bell Home Hub 3000 so that I may get the most of my Orbi RBR50 router. I have seen a lot of discussion about configuring the WAN conn...
- Nov 07, 2020
Did you look at page 27 of the Orbi user manual, where it describes PPoE connections?
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
sparkman
A few things I forgot. I have tested the ethernet and wifi from my affected devices directly with the Home Hub 3000 and i am achieving the desired speeds when connected. However, for instance, my ethernet speeds (with cat6) are about 50% less when going through my Orbi RBR50.
CrimpOn
Nov 07, 2020Guru - Experienced User
- sparkmanNov 08, 2020Aspirant
As yes the 'ole RTFM. Thanks for that. I obviously missed that.
Much appreciated.
