JaySix
Nov 08, 2017Follower
RBR50 Hidden Network
Is it possible to create a Hidden Network, to not broadcast your SSID? I have always used this feature with all my Apple routers and now with the Oribi AC3000 I am not sure if and how I can do this.
Appreciate your help. Thanks.
1 Reply
- DarrenMSr. NETGEAR Moderator
yes you can go to Advanced-Advanced Setup-Wireless settings and then you can uncheck the broadcast SSID check box.
DarrenM
