Geazi
Feb 01, 2022Aspirant
RBR50 how satélite
I live in Brazil and I have a netgear orbi system - RBR50 and a satellite RBS50. and that I bought when I was on a trip to the USA. As my house is big and with bad points of wifi I decided to buy mo...
- Feb 02, 2022
I would like to thank everyone for their contributions.
After studying further, I came to the conclusion that connecting the router with an AP is not the best solution for me, since I will lose one of the great advantages of having a wesch network where you can move between environments and the device will automatically connect to the best node on the network.
I bought wrong. I will try to sell and buy new ones, now taking care to buy right.
thanks a lot and sorry for my english. It's a bit rusty
Feb 01, 2022Guru - Experienced User
There is an option to convert an RBR50 to an RBS50 but it isn't on the official netgear site and isn't even slightly recommened or supported. Theres a good (great) chance you brick your device. If you're so inclined. google is your friend in this.
Geazi
Feb 02, 2022Aspirant
