Gharam
Jul 06, 2020Aspirant
RBR50 I can't access to orbilogin.com
I can't access to orbilogin.com I just saw this update and when I click cont., I saw the second picture... help me guys. (The first picture is in this message. and the second one in t...
Jul 07, 2020Guru - Experienced User
Built in router here by chance? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
