kinwolf
Jan 20, 2022Guide
RBR50 Insane lag spike with the satellites. Firmware or something else?
Hi, I am having insane lag spike(100ms to over 1500ms) between RBS50 and the main router RBR50. I have 2 satellites, both show this behavior. I tried a bunch of stuff I read about in these forums(f...
kinwolf
Jan 20, 2022Guide
Well, good news. I shut down all devices, then redidi a factory reset on all 3. Pings are now back to 3ms on every devices. Life is good once more :)
Reply from 192.168.0.1: bytes=32 time=2ms TTL=64 Reply from 192.168.0.1: bytes=32 time=3ms TTL=64 Reply from 192.168.0.1: bytes=32 time=2ms TTL=64 Reply from 192.168.0.1: bytes=32 time=5ms TTL=64 Reply from 192.168.0.1: bytes=32 time=5ms TTL=64 Reply from 192.168.0.1: bytes=32 time=3ms TTL=64 Reply from 192.168.0.1: bytes=32 time=4ms TTL=64 Reply from 192.168.0.1: bytes=32 time=3ms TTL=64 Reply from 192.168.0.1: bytes=32 time=4ms TTL=64 Reply from 192.168.0.1: bytes=32 time=4ms TTL=64 Reply from 192.168.0.1: bytes=32 time=3ms TTL=64 Reply from 192.168.0.1: bytes=32 time=3ms TTL=64 Reply from 192.168.0.1: bytes=32 time=4ms TTL=64
