dldeuce
Apr 13, 2019Aspirant
RBR50 Intermittent bandwidth cap for PC only
I have a RBR50 Orbi network and a 185Mbps internet connection. Occasionally, I'll see poor performance on my win10 PC on wireless, and I'll do an Inernet speed test to see that I'm capped at 10, 30,...
ekhalil
Apr 14, 2019Master
I would guess that when you have bad bandwidth you would be connected to a disturbed 2.4 GHz channel. When disconnecting and reconnecting or rebooting Orbi the wireless card will always prefer 5 GHz channel and that's why things get better.
I'd do a wireless scan and select a 2.4 GHz channel that is least used by the surrounding and set it as the 2.4 GHz channel.
Do the same also for the 5 GHz channel.
dldeuce
Apr 18, 2019Aspirant
yes, and as soon as I disconnected and reconnected from the PC, I connect back at 5G and get the full bandwidth. You're probably on to something, now the question is why is it connecting to 2.4G? How do I control that?
