kevindubs
Mar 15, 2021Star
RBR50 intermittent DNS lookup issues
I have RBR50 (Firmware V2.7.2.104), with one RBS50 satellite, connected to a CM1000v2 cable modem, Comcast ISP. Starting 3/14, I sporadically get DNS lookup errors. I've tried setting DNS servers t...
kevindubs
Mar 15, 2021Star
One extra note to the above, it does seem to occur more frequently in the evening, less than an hour between errors.
- FURRYe38Mar 15, 2021Guru - Experienced User
Also check your NTP settings. Make sure they are correct and test the DST option to make sure the time is correct.
- kevindubsMar 15, 2021Star
I will try factory reset tomorrow.
No to Armour and Circle.
Basically the same setup we've always had, except for firmware updates. Had the Orbi for years and modem for almost 1 year.
NTP is GMT-5, uto adjust for DST, use defalt NETGEAR NTP and the time is correct.
When was the FW updated and when did you first notice this problem?
- kevindubsMar 16, 2021Star
I changed from "Use NETGEAR NTP Server" to time.nist.gov
Will see what happens. If i still have issues, will factory reset this evening and let you know.
Thanks for the help.
- kevindubsMar 17, 2021Star
Changing NTP server did not help. The problem recurred again this morning. Will try factory reset tonight.
