kevindubs
Mar 15, 2021Star
RBR50 intermittent DNS lookup issues
I have RBR50 (Firmware V2.7.2.104), with one RBS50 satellite, connected to a CM1000v2 cable modem, Comcast ISP. Starting 3/14, I sporadically get DNS lookup errors. I've tried setting DNS servers t...
SlimTrigger
Mar 16, 2021Tutor
I am experiencing EXACTLY the same problems as KevinDubs
RBR50, Firmware V2.7.2.104
ISP is Comcast
Problem started March 14, still here on March 16 - lose internet connection multiple times, generally 1 to 2 hour intervals
Same issue whether I allow ISP to pick DNS (75.75.75.75 / 75.75.76.76) of I manually select DNS (8.8.8.8 / 8.8.4.4)
Problem extends across all devices - wired and wireless, Windows, Android, iOS, and Echo units)
Must reboot the modem to regain internet services'
Nor recent changes to firmware, ISP connection or the devices used.
What is going on, and how do we fix it?
- FURRYe38Mar 16, 2021Guru - Experienced User
Others in that reddit thread methioned checing your NTP settings to ensure they are correct.
What is the Mfr and model# of your modem you use?
If this problem just appeared long after a FW update, seems like this maybe a timing issue with the recent DST time change. No idea why that would effect DNS or Orbi though.
https://geeksadvice.com/how-to-fix-dns_probe_finished_nxdomain-error/
SlimTrigger wrote:I am experiencing EXACTLY the same problems as KevinDubs
ISP is Comcast
- mrkengosMar 16, 2021TutorI did a factory reset last night to resolve per others have suggested on the reddit thread. It's ok so far but it's only been 8 hours. Will report back if I encounter the issue again.
