kevindubs
Mar 16, 2021Star
RBR50 intermittent DNS lookup issues
I have RBR50 (Firmware V2.7.2.104), with one RBS50 satellite, connected to a CM1000v2 cable modem, Comcast ISP. Starting 3/14, I sporadically get DNS lookup errors. I've tried setting DNS servers t...
Mar 16, 2021Guru - Experienced User
Also check your NTP settings. Make sure they are correct and test the DST option to make sure the time is correct.
kevindubs
Mar 16, 2021Star
I changed from "Use NETGEAR NTP Server" to time.nist.gov
Will see what happens. If i still have issues, will factory reset this evening and let you know.
Thanks for the help.
- kevindubsMar 17, 2021Star
Changing NTP server did not help. The problem recurred again this morning. Will try factory reset tonight.
- tangelogeeMar 17, 2021Initiate
Yet another reason to dump DST...
- bdc2021Mar 18, 2021Initiate
Steps to solve the ongoing DNS Lookup issues for all Negear Orbi modules as a result of a Netgear developer introducing a Cobal /Y2000 Daylight Savings Bug 3/14/2021:
1. Full Netgear Orbi Factory Reset
2. Uncheck Advanced>Administration>NTP Settings>Automatically adjust for daylight savings time
3. Update to firmware V2.6.2.104
BTW it took me 3 days with Spectrum Support, a Sectrum Truck rolled to check the cables, a new Sectrum Modem, all new cables - to finally determine it was a Netgear Orbi Daylight Savings Y2k bug!!!!!!!!!!
- kevindubsMar 18, 2021Star
I did factory reset yesterday afternoon, around 1:30pm.
Firmware 2.7.2.104
I changed NTP to time.nist.gov
Automatically adjust for DST is checked
DSN 8.8.8.8/8.8.4.4
So far, so good.
- vajimMar 18, 2021Master
kevindubs wrote:I did factory reset yesterday afternoon, around 1:30pm.
Firmware 2.7.2.104
DSN 8.8.8.8/8.8.4.4
So far, so good.
Nice
Lets hope it all works out for you.
- alokeprasadMar 18, 2021Mentor
Does it matter that my Orbi is 1 hr behind?
It is not set to adjust for DST automatically and did not. It has been working fine.
