kevindubs
Mar 15, 2021Star
RBR50 intermittent DNS lookup issues
I have RBR50 (Firmware V2.7.2.104), with one RBS50 satellite, connected to a CM1000v2 cable modem, Comcast ISP. Starting 3/14, I sporadically get DNS lookup errors. I've tried setting DNS servers t...
SlimTrigger
Mar 17, 2021Tutor
Success (at least for the last 20 hours)
I changed my NTP server to 1.pool.ntp.org
AND I turned OFF "Automatically adjust to daylight savings time"
Then rebooted. No problems since.
- vajimMar 17, 2021Master
SlimTrigger wrote:Success (at least for the last 20 hours)
Until the next firmware update
- mrkengosMar 17, 2021Tutor
Reporting back after 36 hours after factory reset. Everything is working properly as others have also reported. I guess if all else fails, just do a factory reset and it should save you from more headaches. Good luck all.
I'm on latest firmware - V2.7.2.104
- FURRYe38Mar 17, 2021Guru - Experienced User
Thanks for letting us know.
I'd make a backup configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. :smileywink:
mrkengos wrote:Reporting back after 36 hours after factory reset. Everything is working properly as others have also reported. I guess if all else fails, just do a factory reset and it should save you from more headaches. Good luck all.
- 719G2Mar 19, 2021Initiate
I opt for this method instead of factory reset and so far so good - crossed fingers.
- alokeprasadMar 20, 2021Mentor
The articles on dnsmasq were very helpful. Netgear has been fixing this on various devices for quite some time.
Netgear support srticles on dnsmasq
I guess the fix for the Orbi's introduced a bug in DST/NTP part of the revised firmware and got rolled out with the latest updates.
It also explains why I didn't have the problem (I had DST update and traffic meter disabled).
