kevindubs
Mar 15, 2021Star
RBR50 intermittent DNS lookup issues
I have RBR50 (Firmware V2.7.2.104), with one RBS50 satellite, connected to a CM1000v2 cable modem, Comcast ISP. Starting 3/14, I sporadically get DNS lookup errors. I've tried setting DNS servers t...
vajim
Mar 17, 2021Master
SlimTrigger wrote:Success (at least for the last 20 hours)
I changed my NTP server to 1.pool.ntp.org
AND I turned OFF "Automatically adjust to daylight savings time"
Then rebooted. No problems since.
Until the next firmware update
mrkengos
Mar 17, 2021Tutor
Reporting back after 36 hours after factory reset. Everything is working properly as others have also reported. I guess if all else fails, just do a factory reset and it should save you from more headaches. Good luck all.
I'm on latest firmware - V2.7.2.104
