kevindubs
Mar 15, 2021Star
RBR50 intermittent DNS lookup issues
I have RBR50 (Firmware V2.7.2.104), with one RBS50 satellite, connected to a CM1000v2 cable modem, Comcast ISP. Starting 3/14, I sporadically get DNS lookup errors. I've tried setting DNS servers t...
Mar 17, 2021Guru - Experienced User
Thanks for letting us know.
I'd make a backup configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. :smileywink:
mrkengos wrote:Reporting back after 36 hours after factory reset. Everything is working properly as others have also reported. I guess if all else fails, just do a factory reset and it should save you from more headaches. Good luck all.
I'm on latest firmware - V2.7.2.104
NoNo_BadDog
Mar 17, 2021Star
Update... 48+ hours after factory reset all is working properly. Hope this DST/DNS bug will be resolved before fall.
- vajimMar 17, 2021Master
NoNo_BadDog wrote:Update... 48+ hours after factory reset all is working properly. Hope this DST/DNS bug will be resolved before fall.
nice
lets hope that's true.
