kevindubs
Mar 15, 2021Star
RBR50 intermittent DNS lookup issues
I have RBR50 (Firmware V2.7.2.104), with one RBS50 satellite, connected to a CM1000v2 cable modem, Comcast ISP. Starting 3/14, I sporadically get DNS lookup errors. I've tried setting DNS servers t...
riegelj
Mar 17, 2021Initiate
I am experiencing EXACTLY the same problems
RBR50, Firmware V2.7.2.104
ISP is Comcast
Problem started March 14, still here on March 17 - lose internet connection multiple times, generally 1 to 2 hour intervals
Same issue whether I allow ISP to pick DNS (75.75.75.75 / 75.75.76.76) of I manually select DNS - OpenDNS (208.67.222.222 / 208.67.220.220)
Problem extends across all devices - wired and wireless, Windows, Android)
Test Internet button seems to temporarily fix the problem.
Nor recent changes to firmware, ISP connection or the devices used.
ChristineT
Mar 17, 2021NETGEAR Employee Retired
Hello Orbi Community!
Thank you all for your contribution to this issue! Our NETGEAR engineers are looking for users that are still facing this issue to work with them directly to identy the root cause of the issue. If anyone is willing to work with our engineering team to debug this issue in real-time please send me a private message with your contact information and best time to reach you.
We are committed to getting to the bottom of this issue but need your help.
Thank you in advance!
ChristineT
- archpMar 17, 2021Star
- BrentxMar 17, 2021Tutor
Better yet - tell your customers that its a support issue and requires payment to fix despite it being something you insterted via firmware update or other.. oh wait - you already are doing this!
- vajimMar 17, 2021Master
Brentx wrote:Better yet - tell your customers that its a support issue and requires payment to fix despite it being something you insterted via firmware update or other.. oh wait - you already are doing this!
If you'll look around in this forum, several moderators have reached out offering to help. Perhaps you should do that.
- BrentxMar 18, 2021Tutor
Sure... but should I have done that prior to calling support? Is that the new standard... Hunt and peck around for their issues they introduce? Imagine all the old folks getting fleeced by them because of people who call in first..
- DavidDalyMar 18, 2021Initiate
I'm willing! I sent a private message.
- CoffeecupMar 18, 2021Star
RBR50v2
Unsure FW but issues occurred around DST and FW upgrade
Mac Os 10.13.6 High Sierra
xfinity internet
- childre9Mar 19, 2021Aspirant
Same issues as I see many others have in the community. The Orbi network seems to be working and I have internet connectivity on some devices and not on others. For instance, my computer and Rokus work but cell phones say there is no connection to the internet. Sometimes just the Rokus will work and the computers will have the same no internet message as the cell phones. This makes no sense to me. I have rebooted the main and satellites several times.
- l8ncMar 19, 2021Apprentice
A little more information:
IPv6 DNS entries appear to be not working correctly.
If I leave the configuration to "get automatically from ISP", then there is no entry in /tmp/resolv.conf (i.e., no override).
If I put in a DNS entry "use these DNS servers", then the entry in /tmp/resolv.conf is NOT what I entered - it is the value the router gets from my ISP.
I don't know if this is related to the overall DNS problems we've all been seeing.
PS - ROKUs may work (some apps at least) because they have hard-wired IP addresses for DNS servers in the public Internet (e.g., Google 8.8.8.8).
Laptops, phones, and pads typically take the DNS info from their DHCP response and use that; the Orbi always tells them to use the Orbi as the DNS server (192.168.1.1). That works fine until dnsmasq crashes and fails to restart, at which point the Orbi no longer does DNS caching relay or DHCP.
You CAN login and restart dnsmasq. You can setup a cron job to do that automatically, at least until the system reboots (it loses that state). You can also reboot, which will start dnsmasq again.
- hokey777Mar 19, 2021Initiate
childre9, do you have Traffic Metering enable? If so, disabling that and a router reboot should fix it.
That appears to have worked. Phones and computers are online. Netgear should pay you for your help here, but I thank you.
