kevindubs
Mar 15, 2021Star
RBR50 intermittent DNS lookup issues
I have RBR50 (Firmware V2.7.2.104), with one RBS50 satellite, connected to a CM1000v2 cable modem, Comcast ISP. Starting 3/14, I sporadically get DNS lookup errors. I've tried setting DNS servers t...
Mar 17, 2021Guru - Experienced User
If you want your equipment to work and troubleshoot thru the problems then a reset is a valid troubleshooting step. Has been for a long time. Others are posting that is working for them to fix this issue. So try it out.
Also saves time if you have a good working backup configuration that helps to apply after doing a reset. Good users have this one hand.
Or reach out to NG support
If your not satified with your product, find something else.
Good Luck.
archp wrote:
Resetting stuff isn't a solution or downgrading firmware. This is about customer experience. I have 4 satellites and work from home. Also have custom ssids for 2.4ghz, the solution shouldn't be to make customers unscrew the company's screw ups. Literally all of these solutions put the onus on the user. If support was free they would have been notified much sooner as many more people would gave called in and complained. The mere fact that every support call prompts the user to spend more is why they have no clue what's going on. Its like saying everytime your engine stops working in your car, swap out the engine, well I don't have a formula one team at my disposal. Moderators aren't netgear employees either. Just a terrible service and support options for such expensive network gear. This is your halo product and your solutions are reset and spend hours getting back to status quo, how about doing your jobs and fixing it on your end.
archp
Mar 17, 2021Star
That's a very condescending response, if you don't have an alternative to factory reset, then please keep your opinion to yourself 'guru'. If you don't like my response then don't respond.
- FURRYe38Mar 17, 2021Guru - Experienced User
Ill post as I see fit. Thanks.
- archpMar 17, 2021StarPlease factory reset your attitude.
Alternative suggestions:
Good Luck.
- alokeprasadMar 17, 2021Mentor
This is not happening to all. It is now 4 days after the time change and I never lost DNS.
I. have "Automatically adjust for daylight savings time" unchecked and the Orbi time is 1 hr behind.
Does that mattar? All my devices are working correctly, my Win10 PC checks time on its own. DNS is working (I use 1.1.1.1, 8.8.8.8, 208.67.222.222). I think I'll leave everything as is.
