kevindubs
Mar 16, 2021Star
RBR50 intermittent DNS lookup issues
I have RBR50 (Firmware V2.7.2.104), with one RBS50 satellite, connected to a CM1000v2 cable modem, Comcast ISP. Starting 3/14, I sporadically get DNS lookup errors. I've tried setting DNS servers t...
vajim
Mar 18, 2021Master
kevindubs wrote:I've had DST enabled after factory reset.
It's been about 23 hours now, with no issue.
nice....good luck
archp
Mar 18, 2021Star
No factory reset here. This is what I did so far, around 4pm Yesterday, I did the following:
Turn off dst, (live in Cali, so changed time zone to Alaska), pointed ntp server to pool.ntp.org.
So far no disconnections, will update if it goes a full 24 hours.
I also emailed the engineering team all my details as well. Will keep you all posted when I hear back.
- SirVilhelmMar 18, 2021TutorThis is what I did as well, no disconnects so far. Think it's obvious that this is connected to the time change.
Edit: what I did was change the time service to pool.ntb.org and disabled auto daylight saving adjustment. - archpMar 18, 2021Star
Ok so this seems to be working, 24 hrs and no disconnect.
Glad I didn't waste hours doing a factory reset and spend time reconfiguring.
If a factory reset worked for others, great, if you want an alternative, try the below.
Also that is literally the only thing I did, didn't mess with DNS or anything else.
This did the trick. For those looking
I also emailed the engineering team all my details as well. Will keep you all posted when I hear back. - tak1313Mar 19, 2021Luminary
Could the DNS problem be related to this, considering it's not affecting all units?
I also have an Asus router and noticed their most recent update specifically mentions it fixes the above situation - unlike Netgear that never states what their updates are doing.
This article also includes OpenWRT as specifically vulnerable (the other article mentions Netgear as a manufacturer. I believe Netgear routers (among many) is based on OpenWRT?
https://www.helpnetsecurity.com/2021/01/19/dnsmasq-vulnerabilities/
Note- I don't know if this is THE issue, especially since Netgear has the annoying habit of NOT stating what their updates address. I'm just stating a possible source of the issue.
- FURRYe38Mar 19, 2021Guru - Experienced User
Anything is possible. However since some users have disabled DST or made a change in NTP, possible that these two could be related. Seems that for the most part the problem appears to be over after these changes, until the next time we have the time change.
Yes Orbi is based off a build of WRT. If you look at the telnet window when you log in, it gives this information.
tak1313 wrote:This article also includes OpenWRT as specifically vulnerable (the other article mentions Netgear as a manufacturer. I believe Netgear routers (among many) is based on OpenWRT?
- vajimMar 19, 2021Master
tak1313 wrote:Could the DNS problem be related to this, considering it's not affecting all units?
and of course there are generic release notes
- archpMar 19, 2021StarThis is what the netgear engineer said:
We have identified that the traffic meter will cause problem while auto daylight saving time enabled. Since you turn off auto daylight saving time, the issue should be go away. Turn off traffic meter would also avoid the issue. We are working on a trial fix firmware. Will provide to you once it’s ready. Thanks. - vajimMar 19, 2021Master
We have identified that the traffic meter will cause problem while auto daylight saving time enabled. Since you turn off auto daylight saving time, the issue should be go away. Turn off traffic meter would also avoid the issue. We are working on a trial fix firmware. Will provide to you once it’s ready. Thanks.trial fix firmware???
- archpMar 19, 2021StarMaybe he meant a beta firmware to test before they release an official one? That's literally all that was said.
archp wrote:
Maybe he meant a beta firmware to test before they release an official one? That's literally all that was said.Thanks
That's what appears to be happening when they decide to put the newest and greatest firmware update on the server for all to use. Then here comes the 'I gotta it have bunch', who in turn become our beta testers.
Go to be a better method.
