kevindubs
Mar 15, 2021Star
RBR50 intermittent DNS lookup issues
I have RBR50 (Firmware V2.7.2.104), with one RBS50 satellite, connected to a CM1000v2 cable modem, Comcast ISP. Starting 3/14, I sporadically get DNS lookup errors. I've tried setting DNS servers t...
mwhold11
Mar 18, 2021Tutor
I have been experiencing internet connectivity issues and initially thought it was my DSL. After troubleshooting and researching online I used telnet to connect to my Orbi and discovered that dnsmasq was not running which explained why DNS lookups were not running on my system.
As a workaround I created a cron task to run a bash script which uses the ps command to check whether dnsmasq is running and forces a restart if it is not running.
The steps I performed are outlined below:
1. Enable telnet mode using http://X.X.X.X/debug.htm where X.X.X.X is the IP address of the Orbi router.
2. Telnet into the Orbi router.
3. Create the bash script using the following command:
echo 'DNSSTAT=`ps|grep -c dnsmasq`' >/tmp/dnsmasq-test.sh
echo 'if [ $DNSSTAT == 1 ]' >>/tmp/dnsmasq-test.sh
echo 'then' >>/tmp/dnsmasq-test.sh
echo '/etc/init.d/dnsmasq restart' >>/tmp/dnsmasq-test.sh
echo 'fi' >>/tmp/dnsmasq-test.sh
4. Make the bash script executable using the following command:
chmod +x /tmp/dnsmasq-test.sh
5. Create a cron job to run the batch file ever minute using the following command:
echo '* * * * * /tmp/dnsmasq-test.sh' >>/tmp/etc/crontabs/root
The above steps should force the dmsmasq process to reload and should keep DNS outages down to a couple of minutes until a better or permanent fix becomes available.
Please note that changes to the configuration or reboots of the router will require reapplication of the workaround.
mwhold11
Mar 18, 2021Tutor
there was an issue with the first version of the workaround that I posted. An updated version is shown below.
echo 'DNSSTAT=`ps|grep -c dnsmasq`' >/tmp/dns-test.sh
echo 'if [ "$DNSSTAT" == "1" ]' >>/tmp/dns-test.sh
echo 'then' >>/tmp/dns-test.sh
echo '/etc/init.d/dnsmasq restart' >>/tmp/dns-test.sh
echo 'fi' >>/tmp/dns-test.sh
chmod +x /tmp/dns-test.sh
echo '* * * * * /tmp/dns-test.sh' >>/tmp/etc/crontabs/root
