kevindubs
Mar 16, 2021Star
RBR50 intermittent DNS lookup issues
I have RBR50 (Firmware V2.7.2.104), with one RBS50 satellite, connected to a CM1000v2 cable modem, Comcast ISP. Starting 3/14, I sporadically get DNS lookup errors. I've tried setting DNS servers t...
vajim
Mar 19, 2021Master
tak1313 wrote:Could the DNS problem be related to this, considering it's not affecting all units?
I also have an Asus router and noticed their most recent update specifically mentions it fixes the above situation - unlike Netgear that never states what their updates are doing.
and of course there are generic release notes
archp
Mar 19, 2021Star
This is what the netgear engineer said:
We have identified that the traffic meter will cause problem while auto daylight saving time enabled. Since you turn off auto daylight saving time, the issue should be go away. Turn off traffic meter would also avoid the issue. We are working on a trial fix firmware. Will provide to you once it’s ready. Thanks.
- vajimMar 19, 2021Master
We have identified that the traffic meter will cause problem while auto daylight saving time enabled. Since you turn off auto daylight saving time, the issue should be go away. Turn off traffic meter would also avoid the issue. We are working on a trial fix firmware. Will provide to you once it’s ready. Thanks.trial fix firmware???
- archpMar 19, 2021StarMaybe he meant a beta firmware to test before they release an official one? That's literally all that was said.
archp wrote:
Maybe he meant a beta firmware to test before they release an official one? That's literally all that was said.Thanks
That's what appears to be happening when they decide to put the newest and greatest firmware update on the server for all to use. Then here comes the 'I gotta it have bunch', who in turn become our beta testers.
Go to be a better method.
