kevindubs
Mar 15, 2021Star
RBR50 intermittent DNS lookup issues
I have RBR50 (Firmware V2.7.2.104), with one RBS50 satellite, connected to a CM1000v2 cable modem, Comcast ISP. Starting 3/14, I sporadically get DNS lookup errors. I've tried setting DNS servers t...
vajim
Apr 16, 2021Master
FURRYe38 wrote:I won't admit to something falsely if it's not happening with mine. Sorry. If it's not happening to me and you don't belive that thats fine. Think what you will. I'm not giving any false information based on what you believe. We are not here to prove anything to you.
Good Luck.
You're still missing the point. No one is asking you or anyone to admit to anything falsely. It has nothing to do with me believing anything about you or asking you to prove anything to anyone.
My position is if you are NOT or have NOT experienced the same problem that the original poster is going through and then to tell them that a certain firmware works for you with no problems certainly does NOT help your case. Think about it, it's like saying...."I can do it why can't you?" You're talking down to people. Rather just offer your ideas for a fix. Something you seem to have no shortage of.
But as you've told me before you'll continue to post as you see fit.
SidewinderX
Apr 17, 2021Guide
I'm chiming back in to say that I still have found a solution with my system yet, even after a week of back-and-forth with the netgear L2 support (who has not suggested any beta firmware or anything yet, just continuing to ask questions and for debug logs).
My current workaround, which is stable, is that I've put my Orbi system into wireless access point mode and added an old router (Archer C7 with the wifi off) in-line between the cable modem and the Orbi to serve as the router. In that configuration, I've been stable for a couple days now. Obviously not ideal (why did I buy and expensive Orbi if all I can use it for is being a dumb wifi access point?), but it's letting my wife and I work in the meantime.
If the Orbi support folks don't have many ideas, I think my next attempt will be to try some flavor of the Voxel firmware and see if that solves it.
In the spoiler tag below I've added a summary of my past troubleshooting steps that haven't worked:
Spoiler
Issue: Devices on the network repeatedly lose the internet connection for some period of time, which normally presents itself as a DNS issue. It's usually not all devices on the network (for example, my Roku and work laptop may work fine with no interruption, but my cell phones and wife's laptop might not be able to access).
Investigation notes:
* this started after upgrading to the .104 firmware (where I had the traffic meter on).
* I have tried the methods of disabling traffic meter, disabling daylight savings time, changing NTP, changing default DNS servers, etc.
*I've change the wire between the router and the cable modem to confirm the issue isn't on that end.
* I have factory reset the Orbi system (both router and satellite) several times, to no effect including:
- A factory reset while still on the .104 firmware (therefore disabling traffic meter); no improvement
- downgraded to 2.6 firmware, and then factory resetting on that firmware; no improvement
-upgraded back to the .104 firmware, and factory resetting on that firmware; no improvment
*during the investigation, seems more and more clear that it has something to do with the router and the internet routing (DNS/DHCP or something?).
- The router has always been able to run a speedtest from the router to the internet with no issues, even while some of my downstream devices have issues.
- Similiarly, I've never had wireless or wired connection dropouts, so the internal LAN seems to work just fine. For example, I'm able to endlessly ping my NAS device with not issues, even while the actualy internet connection from the device is inconsistent
*Finally, my last step, which seems to working for now, is that I've put the Orbi system (RBR50 and RBS50) into wireless access point mode, and added my old router (a TP Link Archer C7) in-line as the router (with its own wifi disabled). The configuration, with the Archer as the router, has had no issues managing the internet connection, so it seems pretty clear that the issue is in the Orbit LAN to WAN routing in some way.
