Beeldbuisje
May 08, 2022Guide
RBR50 internet connection disappears when connecting to other satellite
I have an RBR50 mesh system with 2 satellites as router setup. When my computing device is connected to one of 3 appliances (main unit as well a satellite), I have fast and stabile internet conne...
May 08, 2022Guru - Experienced User
1. what modem/gateway is it connected to?
2. how is that modem/gateway setup?
3. what firmware is on the router and the satellites?
4. How are the satellites connected to the router? Using a wired backhaul? Wilreless backhaul? and if wired, what switch are they running through?
Beeldbuisje
May 09, 2022Guide
1. Belgian Telenet modem Docsis 3.1
2. What do you exactly mean with this? Coax cable enters this modem. Wifi disabled, LAN directly connected to RBR50. Telenet modem is further in his default settings.
3. Router V2.7.3.22, both satellites are on V2.7.3.22 as well
4. The satellites are connected through a wired backhaul, using a 16 port TP-Link switch TL-SG1016D
