res03yzp
Jun 06, 2019Follower
RBR50 Internet Connection Disconnect Issues
I have an RBR50 and two satellites. I'm currently running V2.3.1.60. Two updates ago, I started noticing problems with the Internet disconnecting. So now once a week or so, I have to reboot the route...
Jun 07, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try a factory reset on the RBR and setup from scratch.
res03yzp wrote:I have an RBR50 and two satellites. I'm currently running V2.3.1.60. Two updates ago, I started noticing problems with the Internet disconnecting. So now once a week or so, I have to reboot the router. I get errors on my streaming devices that I am experiencing low bandwidth then I lose my connection. The fix is always to reboot the router. Before the last two firmware updates, this WiFi mesh has worked flawlessly. Now it's annoying. Has anyone experienced this same problem?
