ssgtweasel
Mar 25, 2020Guide
RBR50 Internet outage - DNS issue
Woke up this morning and not able to access internet. This seems to be intermittent issue for the past few weeks. Besides this morning, this happened maybe a few days ago and then a few times the pre...
ssgtweasel
Mar 25, 2020Guide
Suddenlink is ISP (cablemodem)
Arris SB6190 cablemodem
Mar 25, 2020Guru - Experienced User
Let us know if a full power off and back on with both modem and RBR helps...
That modem model has known vulnerabilities just FYI:
- ssgtweaselMar 25, 2020Guide
I will test later thanks
I guess I don't see how the SB6190 cable modem could be causing the issue if only rebooting the Orbi RBR50 solved the issues I had this morning.
- SW_Mar 25, 2020Prodigy
ssgtweasel , you're not alone running into Orbi DNS bug. There are several threads with similar issues. There's no fix from NG yet, but there are few workarounds. Here is an example of a good workaround until the real fix is released:
dbwiddis wrote:...
Eventually I found that using the GUI to "release" and "renew" DHCP solved the problem without a reboot, and after a bit more research, traced the problem to the "dnsmasq" service running on the router as part of Circle. I was (and am) able to recover the DNS by telnetting into the router and executing "/etc/init.d/dnsmasq restart".
Check this post for more details. Good luck!
Mistakenly referring back to this thread instead of this, which is the intended post.
- FURRYe38Mar 25, 2020Guru - Experienced User
If the system had been working up to this morning, then this may point to an ISP/Modem issue. Hopefully the power cycle will help here.
Just added the info link about the problems with the 6190 for your info only.
ssgtweasel wrote:I will test later thanks
