ssgtweasel
Mar 25, 2020Guide
RBR50 Internet outage - DNS issue
Woke up this morning and not able to access internet. This seems to be intermittent issue for the past few weeks. Besides this morning, this happened maybe a few days ago and then a few times the pre...
ssgtweasel
Mar 27, 2020Guide
Update as of 27 March 2020....
I rebooted the RBR50 last night after work. After rebooting, internet seemed to be not fully functioning…I could ping cnn.com however my sip hardphone wouldn’t register and still confused about that…
After 3 times rebooting, I would get netlogin.net certificate errors on our iphones via wifi. No issue when not using the wifi…I’m still confused what I was getting that…so I ended up resetting to factory defaults and reprogramming from scratch
I did NOT enable parental control/circle/etc
I was able to reset the 2 RBS50s that I have (hardwired)
At this time, everything is functioning well. The iphone using Sprint Wifi calling is now working (as it was intermittent the past week or such)
I can only assume there was some sort of corruption or possible high processor usage (during debug screen, snapshots seemed to be over 85%)
NOTE: I do have the latest firmware
Mar 27, 2020Guru - Experienced User
How was the FW updated, thru auto update or did you manually install the files? Seen bad update bahaviors with auto update pushes. I prefer manual FW file loading and a reset.
ssgtweasel wrote:Update as of 27 March 2020....
