ssgtweasel
Mar 25, 2020Guide
RBR50 Internet outage - DNS issue
Woke up this morning and not able to access internet. This seems to be intermittent issue for the past few weeks. Besides this morning, this happened maybe a few days ago and then a few times the pre...
NKG
Jun 24, 2020Aspirant
Router keeps dropping DNS and wifi stops working, however I am still able to use skyp 4 business and remote apps, teamviewer continues to work. However, I am unable to browse the interenate and look at my Orbi router settings through the app or the web interface. This started happening after updating to the latest firware, any ideas?
Latest Firware - 2.5.1.16
Jun 24, 2020Guru - Experienced User
NKG wrote:Router keeps dropping DNS and wifi stops working, however I am still able to use skyp 4 business and remote apps, teamviewer continues to work. However, I am unable to browse the interenate and look at my Orbi router settings through the app or the web interface. This started happening after updating to the latest firware, any ideas?
