speakercpu
Jun 28, 2020Aspirant
RBR50 internet speed lower on lan ports.
I have a router and sat. 2100 sqft home. I did a speed test inside the Orbi iphone app and Orbi shows the full internet speed. However, when doing a internet speed from a pc connected to a lan port ...
speakercpu
also just saw this post.. https://community.netgear.com/t5/Orbi/Cable-service-at-200mps-but-LANs-out-of-Orbi-WiFi-6-router-max/m-p/1936545/highlight/false#M96258
it seems similar to my issue.
speakercpu
I think I am going to close this out. I am tested the speed using the speedtest app on windows machine, connected to the Orbi router on the lan port, and I get almost all of the paid bandwith minus about 25mb...
Seems like the something must be happening during the day on my network to slow it down some...I will need to look into that.
thanks!
- FURRYe38Jun 29, 2020Guru - Experienced User
Daytime speeds may vary depending on whats going on on your network side of things and also whats going on with the WAN side of things. Rememer, theres alot more people working from home now days so the ISPs are trying to maintain speeds and bandwidth for everyone. You may see speed drop during working hours. Going to be like this for a while.
Good Luck.
