Jaiter
Sep 23, 2022Aspirant
Rbr50 ipv6 6rd is broken
I'm trying to configure ipv6 using the 6rd method, but the rbr50 appears to be just dropping all ipv6 traffic and not allowing anything through. Interestingly I can ping it over ipv6 from a VPS on the...
Jaiter
Unfortunately yes it is the only method.
I have tested using
Ping google.com -6
And used wireshark on both pc and from the /debug.htm page on the rbr50.
I can see DNS queries going out and coming back on the wan, but the router responds with ICMP destination unreachable to the incoming packet.
Also on the wan interface I see the outgoing ping packet, the return echo comes back to the wan interface but just never gets back to the lan side and to the pc.
I have tested using
Ping google.com -6
CrimpOn
Sep 23, 2022Guru - Experienced User
Well, ipv6 was working fine for me, then it was not, and now it is again.
On the IPv6 setup page, I noticed that the ipv6 DNS servers were both "Link Local addresses" (starting with fe80). Having no memory of why that was so, I thought, "I'll just use CloudFlare and Google instead, and changed the setting to this:
Here's what happened:
Original Setting used this DNS server (Link Local address):
fe80:0:fb39:1f6b:f7c3:6db0:0:1
C:\Users\Dick>ping yale.edu -6
Pinging yale.edu [2a04:4e42::645] with 32 bytes of data:
Reply from 2a04:4e42::645: time=18ms
Reply from 2a04:4e42::645: time=10ms
Reply from 2a04:4e42::645: time=11ms
Reply from 2a04:4e42::645: time=16ms
Ping statistics for 2a04:4e42::645:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 10ms, Maximum = 18ms, Average = 13ms
C:\Users\Dick>ping google.com -6
Pinging google.com [2607:f8b0:4007:818::200e] with 32 bytes of data:
Reply from 2607:f8b0:4007:818::200e: time=20ms
Reply from 2607:f8b0:4007:818::200e: time=10ms
Reply from 2607:f8b0:4007:818::200e: time=11ms
Ping statistics for 2607:f8b0:4007:818::200e:
Minimum = 10ms, Maximum = 20ms, Average = 15ms
Here I changed the DNS servers to CloudFlare and Google:
Pinging google.com [2607:f8b0:4007:80a::200e] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 2607:f8b0:4007:80a::200e:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users\Dick>ping -6 yale.edu
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Frustrated now, I stewed around and then tried some more:
C:\Users\Dick>ping -6 harvard.edu
Pinging harvard.edu [2a04:4e42:600::645] with 32 bytes of data:
Reply from 2a04:4e42:600::645: time=10ms
Reply from 2a04:4e42:600::645: time=11ms
Reply from 2a04:4e42:600::645: time=16ms
Ping statistics for 2a04:4e42:600::645:
Minimum = 10ms, Maximum = 16ms, Average = 11ms
Pinging yale.edu [2a04:4e42:200::645] with 32 bytes of data:
Reply from 2a04:4e42:200::645: time=20ms
Reply from 2a04:4e42:200::645: time=11ms
Reply from 2a04:4e42:200::645: time=19ms
Reply from 2a04:4e42:200::645: time=10ms
Ping statistics for 2a04:4e42:200::645:
This means:
- That IPv6 is touchy?
- That on my system IPv6 seems to be working (with Spectrum DHCP)
- JaiterSep 23, 2022AspirantThe frustrating thing for me is that I can see the ICMP 6 ping packets entering the router, the outbound ping to the internet, the return ping from Google servers and then it just disappears inside the orbi.
Is there a way to get SSH Access to the router, it's only embedded Linux after all and would massively help with debugging....- CrimpOnSep 23, 2022Guru - Experienced User
Jaiter wrote:
Is there a way to get SSH Access to the router, it's only embedded Linux after all and would massively help with debugging....Originally, the Orbi router had an option to enable telnet (not ssh, but on a LAN there is not much practical difference). The option was removed a while ago, but there is a Python script on github that will enable telnet for the RBR50 router.
https://github.com/bkerler/netgear_telnet
Login credentials are "admin" and the Orbi admin password.
IPv6 is a total mystery for me. I am comfortable with the way IPv4 works using Network Address Translation to map outgoing connections back to the LAN IP address. It is not clear at all (to me) how IPv6 works. My PC, for example, has quite a bit to say about IPv6:
Ethernet adapter Ethernet: Connection-specific DNS Suffix . : peakview.rr.com Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller Physical Address. . . . . . . . . : 20-25-64-0F-BA-CD DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : 2603:8000:403:bd7c:9913:c3f2:15ee:7438(Preferred) Temporary IPv6 Address. . . . . . : 2603:8000:403:bd7c:84f:4c5c:38aa:a01d(Deprecated) Temporary IPv6 Address. . . . . . : 2603:8000:403:bd7c:81f6:97f6:ee01:acf0(Deprecated) Temporary IPv6 Address. . . . . . : 2603:8000:403:bd7c:882e:d6a9:b1cc:800d(Deprecated) Temporary IPv6 Address. . . . . . : 2603:8000:403:bd7c:c08a:85cb:5743:9103(Deprecated) Temporary IPv6 Address. . . . . . : 2603:8000:403:bd7c:c584:c241:19cf:c53b(Deprecated) Temporary IPv6 Address. . . . . . : 2603:8000:403:bd7c:cdc8:22da:2091:769f(Deprecated) Temporary IPv6 Address. . . . . . : 2603:8000:403:bd7c:d9c2:3fc5:45c4:bc95(Preferred) Link-local IPv6 Address . . . . . : fe80::9913:c3f2:15ee:7438%22(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.1.2(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Tuesday, September 13, 2022 1:43:05 PM Lease Expires . . . . . . . . . . : Saturday, September 24, 2022 1:43:05 PM Default Gateway . . . . . . . . . : fe80::a204:60ff:fe1c:239%22 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DHCPv6 IAID . . . . . . . . . . . : 85992804 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-24-FC-C7-63-20-25-64-0F-BA-CD DNS Servers . . . . . . . . . . . : fe80::a204:60ff:fe1c:239%22 192.168.1.1 fe80::a204:60ff:fe1c:239%22 NetBIOS over Tcpip. . . . . . . . : Enabled Connection-specific DNS Suffix Search List : peakview.rr.comI seem to have "Temporary" IPv6 Addresses. Why?
When an ICMP (Ping) packet is sent off through the router, what is the source address?
And, of course, I am too ignorant to know if there is any fundamental difference between DHCP IPv6 and IPv6 RD.
(Sorry to be so slow......)
Wireshark capture on the PC Ethernet interface of ping -6 yale.edu:
Pretty clear that this RBR50 sends the IPv6 ping responses back to my PC.
