Mattack27
Mar 23, 2021Aspirant
RBR50 is constantly dropping connection wirelessly after a factory reset and firmware upgrade
I'm having a situation where my Orbi RBR50 crapped out a couple of weeks ago (no connection, couldn't log onto the device any longer) for an unknown reason, as nothing in my setup had changed. I had ...
Mattack27
Hey thanks a lot for taking the time to reach out with this possible solution. I really appreciate it. I'm giving it a go now!
vajim
Mar 24, 2021Master
IF your factory reset does NOT help, your problem MAY be related to 2.7. 2.104.
- gjloweMar 29, 2021Aspirant
I am seeing my iOS devices constantly having issues. The WiFi will appear connected, but internet is inaccessible. I have to toggle WiFi off and on, and then sometimes it comes back quickly and sometimes not. I have tried using manually set external DNS servers, but that doesn't seem to change the behavior. This has happened for a while, even before I upgraded to 2.7.2.104 firmware.
- joejoethedogMar 29, 2021Tutor
It was mentioned in another thread that the "Traffic Meter" function may be the cause. I have been having the same trouble after the latest firmware 2.6.2.104, and even when Traffic Meter is on it is not showing any metrics, so I agree there seems to be some problem with it. Turning off "Traffic Meter" should fix your issue.
https://community.netgear.com/t5/Orbi/RBR50-dropping-devices/m-p/2077628/highlight/true#M118101
-Joe
- gjloweMar 29, 2021AspirantI will give it a try. Thanks!
- Who_am_IMar 29, 2021Initiate
I'd recommend V2.6.1.40 as it seems much more stable. My MS Teams was constantly complaining about dropped connection and my web page would freeze in the middle of loading after I went to the latest version of firmware. I reverted back to V2.6.1.40 and it seems to fix the problem.
