Mattack27
Mar 23, 2021Aspirant
RBR50 is constantly dropping connection wirelessly after a factory reset and firmware upgrade
I'm having a situation where my Orbi RBR50 crapped out a couple of weeks ago (no connection, couldn't log onto the device any longer) for an unknown reason, as nothing in my setup had changed. I had ...
Apr 05, 2021Guru - Experienced User
Did you reset the base unit as well. If not, this should be done as well if the problem appears again.
