vipulpatel
Mar 09, 2021Aspirant
RBR50 is not working after firmware upgrade on March 7, 2021
Lost internet connectivity on March 7th. The RBR50 light was blinking. Waited close to an hour. The light was still blinking. Did some reading on NETGEAR Community about this issue, and as per so...
Mar 09, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- vipulpatelMar 09, 2021Aspirant
Firmware: Since, I cannot connect to RBR50 or RBS50, I am not sure on what exact Firmware version is running on it. But, after 3rd reset on Sunday (March 7), when it came back up, I remember seeing Firmware version 2.5.something on the details page. And when I checked, if update was available, it said update was available. I did not make a note of that firmware version. I wish I took a screenshot of it. I did not click on upgrade. Then I lost internet again, this time it was exactly 24 hours after my successful reset (I think) on March 7. Since then I am not able to access RBR50 or RBS50s. I must not be doing it correctly.
I have Verizon FiOS for my internet service. I checked the Verizon's box, it says Verizon ONT I-211M-L. I hope this is the Mfr & Model#. My RBR50 Internet Port is connected to the ONT via ethernet cable. I have this set up since I purchased Netgear Orbi in Sept 2019.
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update? On the RBR50 my power down durations have been between 1 and 10 minutes, except for one power down, which was close to 3 hours long.
My initial Factory Resets were holding (press) the Reset button between 10 and 30 seconds. Today, after some reading, here is how I performed the reset.
1) Power on RBR50,
2) Press the Reset button, and keep it pressed for 1 minute and 45 seconds,
3) During this 1 minute and 45 seconds, here is what I did
a) around 35th second from the time I pressed the Reset button, I powered off the RBR50, by pressing the Power button
b) around 70th second from the time I pressed the Reset button, I powered on the RBR50, by pressing the Power button
c) around 105th second from the time I pressed the Reset button, I released the Reset button
Here is what I observed on the power light, during this 105 seconds, and beyond: During the first 35 seconds (3-a scenario), the power light remained solid green. During the next 35 seconds (3-b scenario), no power light. During the last 35 seconds, the RBR50 came up with solid green power light and within 2-3 seconds it turned to solid red power light and about 2-3 seconds from that time, it started blinking and remained red blinking during this period and even after I released the Reset button. Then I waited few minutes, while it was kept on blinking red. Then I owered it off, waited for about 2 minutes and powered it back on. The power light came up solid green and router kept on blinking white light forever. I connected my laptop to ethernet port. So, the RBR50 had only two connections. One power and second laptop. No connection to Internet and the other two LAN ports. I have downloaded the Firmware version V2.7.2.104 img file on my laptop that I was manually planning/hoping to upgrade my RBR50 to, if I can connect to it. But, I cannot connect to the router, through web browser. :-(
Sorry, for too much details.
- FURRYe38Mar 09, 2021Guru - Experienced User
Ok lets try this, disconnect the RBR from the ONT and disconnect ALL other wired devices from the RBR accept for 1 wired PC or laptop.
Press the reset button for 15 seconds in back then release.The top ring should start blinking WHITE then slowly pulsate WHITE.
Use IE11 or Edge or Firefox browser to connect to 192.168.1.1 after the top ring is pulsating WHITE. If you can get here, you should be met with a page that says setup using the Orbi app. HOWEVER scroll own to the bottom of this page and select Setup using a web browser if the app is not being used. Which we won't be using.
This wil start the web page setup wizard. The wizard will say it can't detect a internet connection, do you want the wizard to continue to help with this or you can continue to manually set up the RBR. Select manually setup. Walk thru the wizard and complete it. I supposed you can add the RBS here if you like. Might was well. IF they can be added, then we can check ther FW versions. You don't have to add them now if you don't want to.
IF you can complete the setup wizard, you should be able to log in to the RBRs web page again at 192.168.1.1 with your new admin password.
Check the FW version thats loaded.
IF you can get the RBS updated as well, you can log into there web pages by using the IP address given to them by the RBR seen on the Basic tab/Connected devices page on the RBR.
Let us know where in this list you got to
First of all FURRYe38 , I really appreciate your help and prompt responses.
Like you suggested, I connected my laptop to RBR50, on one of the three LAN ports. Turned of Wireless radio on my laptop. Connected power to RBR50, with Power Switch in off position. I pressed the Power button, to power on the RBR50. Solid green power light and no light on top ring, solid, blinking or pulsating. I pressed the Reset button with a pin for good 15-17 seconds and then released it. No changes in any lights. Power light remained solid green, and bothing on top ring.
Then I powered off the RBR50 by pressing the Power button. Left power cable connected to wall and ethernet cable to laptop, Now, I pressed the Reset button with a pin and then pressed the Power button on RBR50. Power light started with solid green, turned to solid red within couple seconds and then turned to blinking red couple more seconds later and remained blinking red. I released the Reset button about 30 seconds from the power light was blinking red. The power light remained blinking red. Waiting about two minutes and pressed the power button and pulled the power from wall. Waited another two minutes and plugged power to wall and then pressed Power button on RBR50. Power light came up solid green and blinking white light on the top ring. It is close to 30 minutes now, and the white light is still in blinking state (not pulsating yet). Laptop does not have IP, when I check by "ipconfig" command on cmd window. Still tried 192.168.1.1 on Edge. Not connecting to RBR50, as I thought.
Thanks again!!!
