deerpark11788
Oct 12, 2020Aspirant
RBR50 is showing 2 2.4GHz SSID and 2 5GHz SSID
Hello, RBR50 is showing 2 2.4GHz SSID and 2 5GHz SSID, 1 secured and 1 unsecured. How to get rid of the unsecured SSID. I have one Satellite, the router in basement and satellite is in the first fl...
deerpark11788
Yes, 2 SSID's for both 2.4 and 5 GHz.
If the 2 SSID's issue still persist, what is next option?
Oct 12, 2020Guru - Experienced User
Do you have WPA2 and AES selected on the RBRs wireless settings page?
What FW version are you using on the RBR and RBS?
deerpark11788 wrote:Yes, 2 SSID's for both 2.4 and 5 GHz.
