ziggyray
Jul 01, 2019Aspirant
RBR50 is slower than my isp coming into router
Hello, I am loosing about 100mbs from what I get from isp jack to what I get wired to the orbi router and also if i do a speed test on orbi router it is more than I get from a wired connection on my ...
Jul 01, 2019Guru - Experienced User
Do you have an ISP Modem or just a wall jack where the ISP servcie comes in at?
Has a factory reset and setup from scratch been performed since the FW was updated?
- Ursa99Jul 01, 2019Star
RBR50 and 2 satellites. FW 2.3.1.60 OS=Windows 10, Android Pixel 3, Iphone 6.
I have a similar issue. DL's are about 1/2 of uploads. I've done a paperclip reset to no avail. Running in access point mode. Main router shows correct DL and Upload speeds. If there is a more thorough reset procedure I'd be willing to try that.
I'm on the lastest firmware and it was updated automatically. In fact the last 3 updates were all done automatically and this is my first speed issue.
Any help much appreciated,
Ursa
- FURRYe38Jul 01, 2019Guru - Experienced User
Ursa99 wrote:RBR50 and 2 satellites. FW 2.3.1.60 OS=Windows 10, Android Pixel 3, Iphone 6.
Ursa
The router is an TPLink Archer C7. I have my PC connected directly to it and the DL and Uploads are perfect.
- ziggyrayJul 02, 2019Aspirant
no modem is just a wall jack because I have fiber all the way to house and can get 1gb service but cant even get the 300 I have now so tryin to fix before I upgrade,it is up to date firmware,one satilitte,single level house, I am going to try a factory reset and see if it helps next.
