Doolamatic
Aug 29, 2020Aspirant
RBR50: Issue connecting to chromecast
I have a ORBI RBR50 with one RBS50 satellite and have been using a chromecast to stream video however recently the speed of the wifi connection to the chromecast has dropped to about 1Mbps, all other...
- Aug 29, 2020
Thanks for the quick response. All other devices on the network are achieving good speed, about 100Mbps, it is just the chromecast that has the slow speed. I haven't tried setting up the Orbi in router mode. I will look at this tomorrow if I can't find an alternative solution. I turned the chromecast off and on again which seems to have fixed the speed at the moment. If it returns to the slow speed I will look to set at the Orbi as the router.
Doolamatic
Aug 30, 2020Aspirant
Thanks plemans ,
After several factory resets of the orbi router and a couple of hours of frustration, due to incompetence on my part, I have set the modem into bridge mode and things seem to be working so far. I hope that this will solve the problem. I will check it again tomorrow and ensure that it has not reverted back to the slow speed. I will post to confirm either way. Thnaks for the quick help, greatly appreciated.
Mstrbig
Aug 30, 2020Master
Doolamatic wrote:Thanks plemans ,
For some reason and not all the time, I find Orbi products have a hard time resetting. I just had an issue yesterday resetting an Orbi RBS40V. It kept trying to pair and then turn magenta. After the 3rd hard reset, it finally paired.
