PDXjon
Jun 05, 2020Aspirant
RBR50 issues with xfinity
I am running an RBR50 2 node Orbi AC3000. I recently changed from Frontier to Xfinity. Installed 1 Gbps service with a XB7-T xfinity wireless router/modem. I am hardwired Ethernet cable to the xfini...
- Jun 15, 2020
So, after a week away from home, I did a factory reset on the Orbi and rebuilt the network. I also did a restart on the Comcast XB7, which is a WiFi6 gateway (modem/router). When I did the factory reset, the Orbi also did a firmware update. After the firmware update the Orbi works with no issues and the Xfinity router is set with bridge (DISABLED) and wifi on. At this point I am pretty convinced that it was the firmware update that might have done the job. I should note that I did multiple tries with bridge enabled, wi-fi off, etc. none worked. And the Orbi would NOT recognize the Xfinity Internet with the XB7 gateway set to bridged enabled. Go figure! Thanks to all for the assistance, now working great.
Jun 05, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
PDXjon wrote:I am running an RBR50 2 node Orbi AC3000. I recently changed from Frontier to Xfinity. Installed 1 Gbps service with a XB7-T xfinity wireless router/modem. I am hardwired Ethernet cable to the xfinity modem, 6' of spearation. Since the installation I have not been able to access Prime Video (I get a Something went wrong message) or Disney+ on my Roku's and I get 404 NOT FOUND errors when trying to access some websites. This is occuring on Windows 10 and Android devices. I also tried to do an Android system download and it would not connect to the download server. The wi-fi is turned on for the xfinity router.
Is there a configuration that needs to be changed on the Orbi? Configuration change on the xfinity? Or do I need to turn the wi-fi off on the xfinity router? Any other thoughts?
