PDXjon's avatar
PDXjon
RBR50 issues with xfinity
I am running an RBR50 2 node Orbi AC3000. I recently changed from Frontier to Xfinity.  Installed 1 Gbps service with a XB7-T xfinity wireless router/modem. I am hardwired Ethernet cable to the xfini...
  • PDXjon's avatar
    PDXjon
    Jun 15, 2020
    So, after a week away from home, I did a factory reset on the Orbi and rebuilt the network.  I also did a restart on the Comcast XB7, which is a WiFi6 gateway (modem/router). When I did the factory reset, the Orbi also did a firmware update. After the firmware update the Orbi works with no issues and the Xfinity router is set with bridge (DISABLED) and wifi on. At this point I am pretty convinced that it was the firmware update that might have done the job. I should note that I did multiple tries with bridge enabled, wi-fi off, etc. none worked.  And the Orbi would NOT recognize the Xfinity Internet with the XB7 gateway set to bridged enabled.   Go figure!  Thanks to all for the assistance, now working great.
