avicar
Apr 18, 2020Aspirant
RBR50 keep disconnecting at random times
Hi Community, After a lot of searching I bought an Orbi RBR50 with 2 Satelights. Was easy to set up and internet speed was great. After a day or two it started disconnecting from the internet at le...
Anonymous
Apr 18, 2020The fact that even NG support is advising users to revert to 2.3.5.30 should be proof alone for the disbelievers who hold on to their dozens of useless questions
avicar
Apr 19, 2020Aspirant
Can someone suggest a solution please ?
thank you about the reply on UPnP but I wasn't clear if you think that the fact that it is enabled is the source of the disconnects or not. I do see many past posts debating whether to turn it off or not but we do have XBOX and I need it to continue working. Would stuggle with XBOX only if UPnP is the source which I didn't see a definite post saying it is from NG
This is a great product when it works. If it continue disconnecting I'm going to return to the store and never buy NG again. It is really quie embarassing that I need to deal with such a thing on my own. I expect such a high end product to be ressilient to whatever is cauing this
