avicar
Apr 17, 2020Aspirant
RBR50 keep disconnecting at random times
Hi Community, After a lot of searching I bought an Orbi RBR50 with 2 Satelights. Was easy to set up and internet speed was great. After a day or two it started disconnecting from the internet at le...
Apr 20, 2020Guru - Experienced User
NG isn't advising users to revert FW when new FW has been made available:
https://kb.netgear.com/000061838/RBR50-RBS50-Firmware-Version-2-5-1-16
avicar wrote:Hi Community,
After a day or two it started disconnecting from the internet at least 3 or 4 times a day.... This is really really annoying and doesn't match a high end mesh like Orbi and the price it costs.
I'm minutes away from returning it.
Data -
- Every time there is no internet at the house, disconnecting the cable to the wall (internal from ISP is directly from the wall, no router or log-in needed) and connecting back solves the problem
- Reading around the community there was an advise to change the lease timer, i changed it to 750 through telnet. Nothing changed.
- I contacted Orbi support and they made me downgrade Firmware to 2.3.5.20. Nothing changed. I still get disconnects at least 3 times a day
At this point I'm out of solution. This is really disapointing for a procut like this and I'd appreciate help
thank you
- Retired_MemberApr 20, 2020
The fact that even NG support is advising users to revert to 2.3.5.30 should be proof alone for the disbelievers who hold on to their dozens of useless questions
