chubbyhubby
Feb 02, 2020Aspirant
RBR50 Keeps disconnectiog
Greetings All, 1st post, so a total newb on this, needless to say. I've had the RBR50 for over a year, but recently it shows the magenta ring at least 3 times a day. I normally unplug & plug back i...
chubbyhubby
Feb 09, 2020Aspirant
Many thanks!!! I've just installed it and will follow up if there are any issues. It's a shame that the fix was so difficult to find. Most people (myself included) would find it easier to just think it's a bad router, and switch to another brand, like Eero. You'd think Netgear could have at least sent an email alert advising on the upgrade......
Feb 10, 2020Guru - Experienced User
NG does send out emails when security updates are available. v2.5.1.8 wasn't a security update.
